Basic setup OTX 2.2.0, Radio = Taranis+
You can post settings from the unit here.
Share and compare your configuration with other pilots!
RidgeMan
This is my setup... 2ail, 1ele, 1rud. With swA in the up(away) position they Aero is in Stabilized +Head Lock (self leveling) mode, the gain is controlled by the left slider using Curve 2, When swA is in the middle the Aero is off.. gain 0, When swA down(toward bottom) the Aero is in Head Lock mode and the gain is controlled by right slider. This way adjustments to the modes gain can be fine tuned and I may lock them in at some point. I'm also including the sound files I created (.wav) The AeroOTX22 will need to be renamed with the .otx extension. I guess you can't upload certain file type here? Also HdLck.txt and LevelM.txt need to be rename to .wav
Also included is the Aero config file .4ds but it is in the next post... 3 attachments is the max
LevelM.txt
(38.29 KiB) Downloaded 1457 times
HdLck.txt
(43.19 KiB) Downloaded 1441 times
AeroOTX22.txt
(1013 Bytes) Downloaded 1389 times
RidgeMan
This goes with the previous post.
Aero_fixed_6-1.4ds
(255 Bytes) Downloaded 1450 times
Hello!
Many thanks for your settings!
We will fix the problem with extensions, so you can upload otx files too.
Your support is really appreciated.
RidgeMan
It's not a big deal... as long as it is explained to who ever wants to use them... also, RCGroups forum has the same problem... it doesn't accept certain file extensions. I am considering starting a thread on RCG for the Aero... I've search for information there and really couldn't find much? it wouldn't be to compete with this resource but to try and reach a wider audience.
Thanks for your help,
ZeXx86 wrote:Hello!
Now the extensions are allowed, so you can upload your files now.
Spirit Aero is quite new and flying season is starting right now, but I am sure there will be lot of info soon.
Thanks!
