Oxy 2 setup
Here you can find Oxy 2 setup for 3D.
Motor: stock Lynx, 11t pinion
ESC: Castle Talon 25
Servos: 3x Lynx DS-895-HV, 1x E-flite EFLRDS76TJ
Blades: main - stock plastic, tail - stock plastic 38mm
FBL: uSpirit
Battery: Tattu 3S 850mAh 75C
Flight behavior is rock stable, precise, everything was working from the beginning very well.
There was just one issue of the kit - ball linkages - all were very tight. It was necessary to fix it so everything is butter smooth.
Tail is holding exceptionally well (84% gain), although Travel range is way too big due to short arm (the first hole).
oxy-2.4ds
(255 Bytes) Downloaded 479 times
