Spirit Gov above 4000 RPM
Scout
i want to give the spirit gov a try in my oxy 3, the problem is that the maximum rpm i can set in the software is 4000, but i want to fly with 4200 rpm.
The gear ratio at the oxy is 12,72 so 12,7 in spirit software. Is it possible that i "manipulate" the software with a wrong gear ratio to get a higher HS?
4000/4200 = 0,95; 12,7x0,95 = 12,1 so when I set the gear ratio in the software to 12,1 instead of 12,7 spirit will display me 4000 but in real life i will get 4200, right?
Is this possible or will this influence the spirit governor?
Maybe it would be possible to allow maximum HS in the Software over 4000, especially now with the micro spirit, because I think there are many people who need more HS with their micro spirit, e.g. for a oxy 2 or a blade 180 CFX or something like that.
Coco66
+1 for the limot to be set higher!
Meanwhile, read this, the trick uo need is clarified and explained somewhere right below the middle of the page:
http://spirit-system.com/phpBB3/viewtop ... &view=next
Scout
Thank you :)
In version 2.5 we plan to increase the limit.
