Basic Aero setup
Gauchers
Is there a guide yet for basic aero setup? Will the Aero ever support more channels, such 2 Ail + 2 Elev + 1 Rudder (common jet setup)?
Thanks,
Roger
we have the Setup wizard embedded in the software which should guide you through the entire setup.
As you can see here http://aero-man.spirit-system.com/index ... iring#GYRO
2 Ail + 2 Elev + 1 Rudder is already supported for some time.
You will need the Spirit Pro unit for this.
Gauchers
Excellent - thank you for the quick reply! I have the Spirit Pro FBL - I can flash the firmware & use as an aero gyro correct?
Yes, anytime you wish.
