Version 1.0.24 released!
Posted: Wed 09. Jul 2014 11:52:12
Version 1.0.24 was released right now!
It brings many new features and improvements:
  • Improved geometry correction - automatic geometry correction just behaves very natural, which results in more precise flight, better pirouette optimization and also better behavior in fast forward flight
  • Rudder steering is even more direct - the algorithm for rudder steering was re-implemented so you can have even more direct feeling.
  • Better support for DSM2 and DSMX satelittes - the pairing process was separated for both types.
  • Stabilisation mode was extended - the stabilisation mode can be configured for coaxial-like behavior or even for scale flying now.
  • New support for paddle mechanics - you can fly with paddle equipped helicopters as easily as with flybarless heli now!
  • LOG saved to the unit - the unit is able to detect a major problem on your model and to record whole flight log permanently! Now also detects low voltage.
  • Frequency analysis is more precise - thanks to precise sensor calibration.
  • Mobile app is able to show you differences between a settings you did.
  • Frequency analysis and LOG is completely described in the manual now.
  • Improved configuration software - parameters are described in a better way in tooltips, Stabi tab is tied with Function value, etc.
Changes from previous version 1.0.23 in your settings:
  • All settings from previous version are untouched. You do not need to configure anything.
  • We just recommend to set the value of Rudder dynamic as you prefer.
Re: Version 1.0.24 released!
Posted: Thu 07. Aug 2014 0:20:59
Small update was released right now (version 1.0.24.1)!
It brings following changes:
  • PPM RX support in the wizard was added.
  • Fixed receiver type selection in the wizard (in case of different settings).
  • Splash screen in the software was improved.
  • Stabilisation is working even more precisely.
Configuration should be untouched. It will be recognized as 1.0.24 still.
Update is not necessary but we recommend it!
Download it here :arrow: http://spirit-system.com/index.php#3
