[SOLVED] Shopping List - FrSky and Spirit
Posted: Mon 19. Jun 2017 5:36:32
Hi all.
Sorry for newbie basic questions, but I want to confirm a few things in small steps.
I have recently purchased a Taranis X9D Plus and have had a Spirit FBL for some time. The plan is to use this with a Compass Warp.
I will order a FrSky X6R receiver and a sensor so mAh consumption will be known. I would also like the idea of OpenTX Integration and telemetry data so will need the FrSky integration cable http://store.spirit-system.com/en/acces ... cable.html
But what about channel data transmission protocol between Rx and FBL unit? The manual does not specifically show a connection type wiring diagram for a FrSky receiver but the OpenTX setup guide page states "PWM, PPM or SĀBus". I would just like a single cable from Rx to FBL to transmitter channel data, so this rules out PWM.
What should I be using - PPM or SBus?
I thought S-Bus was a proprietary system offered by Futaba but I see the X6R Rx has an SBUS port. That is confusing for a newbie.
And what is SRXL/SUMD protocol. Is that the one to use?
Next question will be which cable is needed between Rx and FBL unit.
Thanks.
Thanks.
