OpenTX Telemetry with GPS module issue
jweber
I've found that the FrSky GPS module blocks the Spirit telemetry values from being sent to the radio. The RPM and Fuel values do not either get updated and they can not be discovered when the GPS module is wired into the SPort channel. The LUA scripts seem to work however. I've bypassed the module on this model and everything works as it should.
thank you for the report.
We will try to find the problem. However it is also possible that the issue might be in the OpenTX firmware as we know from other sensor (MLVSS) that the OpenTX devs fixed it with update. There was quite same compatibility issue.
We will contact FrSky.
jweber
Did the latest release resolve this?
No, the issue seems to be in the GPS module itself, but OpenTX update should solve it soon.
