Update 2.4.2
gerry
Hello tomas in the new description of the Uodate 2.4 is. Is supported by Spirit Aero. What does that mean now exactly.Can the Aero software now be adjusted by Jeti transmitter? Liebe Grüße Gernot
Greetings Gernot
where you can see this message?
It was related to version 2.4.0, while the current one is 2.4.2.
But regarding Jeti and Aero nothing changed - you have to ask Jeti as the problem is just there.
gerry
Support for μSpirit unit:
Full support of the micro Spirit.
Compatible with all peripherals.
Can be used on helicopters of 130 - 250 size.
Support for ESC/Motor driven rudder.
New parameter Rudder - Control type to allow selection of the rudder drive.
NOTE: Will be supported by Spirit Aero firmware.
IMPORTANT: Older firmwares are not supported
Greetings Gernot
Yes, this mean that μSpirit will be supported by Spirit Aero and you can fly with aircrafts also with this unit.
Nafets77
Will we have higher rpm available for the governor on a future release?
Keep up the good work :)
Yes.
Thank you!
derailleur
I have problem, I update a 2.0.1 firmware to 2.4.2 (with mac)...All is ok but the spirit is not recognize when I plug it on my mac. Only demo mode :evil:
Coco66
Try installing again the Mac software and the drivers.
derailleur
I have 7 spirit ...On my oxy(s), updated before ( they was in 2.4.1 version) all is ok for the 2.4.2...juste 2 helis that was in 2.0.1, the spirit is not recognize after flashing in 2.4.2 version...
So I think it's ok for he software. I have also a Windows PC and it's the same that the mac. No recognize...
Coco66
But they still work properly?
