Page 1 of 2
[SOLVED] FrSky Transmitter Setup Guides?
Posted: Thu 06. Jul 2017 19:25:24
by UFOking
I just switched from Spektrum to Frsky and I'm completely lost.
I don't even know how to setup channels and other basic things.
I used Spektrum for many years and didn't have a single problem setting up everything.
Are there any transmitter guides for Frsky available?
Or maybe someone could be so kind and send me his model setup so I could upload it to my radio and go from there.
Currently I have a Taranis Q X7 untily my local hobby shop doesn't get the Horus x12s back in stock.
I'm setting up my heli with the X4RSB.
Many Thanks!
Re: FrSky Transmitter Setup Guides?
Posted: Thu 06. Jul 2017 22:40:12
first from all I recommend to install the Companion software.
You can download it from the Open-TX web page.
There you can configure your radio easily (load and upload your changed radio profile).
We have prepared finished profile for Taranis X9 - http://manual.spirit-system.com/index.p ... PE_Profile, it can be used with your X7 after a minor changes.
We will prepare profile for X7 so you can just load it and fly with no other configuration.
Posted: Fri 07. Jul 2017 4:57:28
by UFOking
thank you very much ZeXx86!
Will download the profile and upload it to my radio and go from there. This should help quite a bit.
And when the X7 profile is ready, please let me know.
Thanks!
Posted: Sun 09. Jul 2017 14:43:39
by UFOking
I looks like, I will have to wait for you to prepare the X7 profile, because I just can't get it to work.
With Spektrum, it was a piece of cake...
Guess I will have to learn a lot about OpenTX, before I can set up a helicopter by myself.
Setting up my quads on the other hand, was a piece of cake with OpenTX.
Regards!
Posted: Sun 09. Jul 2017 16:23:40
OK, we will try to upload the profile tommorow.
Posted: Sun 09. Jul 2017 16:27:09
by UFOking
Great, thank you very much, this will not only help me, but I think many others out there also.
Posted: Sun 09. Jul 2017 16:50:03
by jamespontones
UFOking, I can try to help where I can. I understand OpenTX reasonably well. I use an X9D Plus instead of the X7 though.
Posted: Sun 09. Jul 2017 16:59:37
by UFOking
jamespontones wrote:UFOking, I can try to help where I can. I understand OpenTX reasonably well. I use an X9D Plus instead of the X7 though.
Thanks, but let's first wait for ZeXx86 to upload the profile and if I than need any help, I will reach out to you, OK.
Posted: Sun 09. Jul 2017 17:07:48
by jamespontones
UFOking wrote:Thanks, but let's first wait for ZeXx86 to upload the profile and if I than need any help, I will reach out to you, OK.
No problem UFOking. It takes some time to break your thinking away from the way that the main commercial radio manufacturers operate like Spektrum & Futaba. Once you do it becomes fairly easy to change things.
Posted: Tue 11. Jul 2017 9:16:37
Here we have profile for the Taranis Q X7:
http://spirit-system.com/dl/opentx/Spirit-FBL-x7.otx
You can just start the Companion software, open it and import.
It is possible you will need to recalibrate the sticks.
