Cable for µSpirit and Jeti EX
Blademaster
do I have to order an additional cable to connect a Jeti Rex 3 receiver to the µSpirit ?
Regards,
Dirk
If you want to use EX Bus, then you will ideally need Jeti integration cable and 2x JST-Servo cables.
If you want to save a weight, you can do your own jeti integration cable just by buying for example JST-RX cable and combining it with supplied JST-RX cable.
1. Plug off orange wire from the JST-RX with a needle.
2. Use any free JST connector or use it from other cable such as JST-RX so that there is no wire in it.
3. Connect orange wire from the step 1 to the free JST connector in the same position as it was. So basically it will look like Jeti integration cable, but with 2 JST connectors and 1 servo connector at the end.
If you do not need integration, you can use supplied JST-RX for UDI or PPM connection. So in this case nothing else than supplied cable is needed.
Blademaster
Thanks for the info !
