Trouble PC Connect
gerry
Hello Tomas!
I have one of my 4 Spirits a problem with the connection to the PC, it can no longer connect, over the Jeti control I have access! With all other Spirit units it functions as usual!
What can I do?
Or am I to send it to you?
Greetings, Gernot
Greetings Gernot
Probably you have enabled Kontronik telemetry without reading noticement that USB connection is temporarily disabled :)
You can just turn off transmitter, then USB connection will work and you can disable Kontronik telemetry.
gerry
Hello Tomas!
Thanks for your quick help, I had no longer thought that I must make the transmitter out!
Everything OK again!
Can not you answer my question because of the Goblin 280 Fireball.If important for the first flight of the cyclic and the stern sensitivity, so I do not experience an evil surprises at the first start!
For the 700 helicopters, I set the multiplier to 1.30
best regards
Greetings Gernot
