Kosmik Telemetrie???
Posted: Sat 29. Jul 2017 19:53:38
by gerry
Hello Tomas!
There are still problems with the RPM at Kontronik Cosmic Telemetry / Jeti !!
Sensing Divider = 1
Gear Ratio = 1.0
Kosmik
Motor poles 14
Subclause 10.18: 1
The telemetry display outputs 160 RPM, but it should be approx.1600RPM ??
What can be the error here?
I have already tried everything!
Ask for solution !!
Greetings, Gernot
Re: Kosmik Telemetrie???
Posted: Sat 29. Jul 2017 19:58:38
Leave default settings in the ESC and set parameters in the Spirit. Then it will work!!! :)
Posted: Sat 29. Jul 2017 20:35:02
by gerry
Hello Tomas!
I have already tried this,
Kosmik
Pole 2(Default)
Understanding 1.0: 1
And Spirit
Sensing Devider = 7(14 Pole)
Gear Ratio = 10.15
Completely false ad?
Something is wrong here??
Posted: Sat 29. Jul 2017 20:41:03
This should be good.
Do you have the latest firmware version? (2.4.2)
Posted: Sat 29. Jul 2017 21:04:32
by gerry
Yes I have the 2.4.2 on it!
I do not understand waru it does not work?
Please try again and try to find a solution!
Posted: Sat 29. Jul 2017 21:07:04
We have many models where it is working very well.
What value do you see right now?
Posted: Sun 30. Jul 2017 7:44:46
by gerry
Hello Tomas!
The displayed RPM = 432 RPM
It would be about 1600 RPM.
Perhaps it is because I have the Kosmik default 2 Pole?
I hope there will be a solution, we are four pilots with several helicopters and they are all waiting for the problem to be solved!
Greetings, Gernot
