Telemetrie Cable Hobby Wing?
gerry
Hello Tomas!
Please provide short information for the assignment of the telemetry cable for Hobby Wing!
As far as I could see is orange equal and red and brown exchanged?
Is that correct?
Greetings, Gernot
Greetings Gernot
here are the connection details:
gerry
I really only wanted to know whether the telemetry cable for Hobby Wing the color brown and red between the connectors is exchanged. I have still a Kontronik cable and I would like to convert.
Greetings Gernot
Nothing is exchanged - it is original Telem UNI cable.
Red is not connected internally to anything.
gerry
You understand unfortunately my question is not correct. I would like to make a Kontronik cable, a unit cable.
Greetings Gernot
Ah, I guess you want to make Jive cable. Kontronik cable is very different.
Jive cable has modified cable as described in this page:
http://manual.spirit-system.com/images/ ... Esc-ji.jpg
gerry
No, I would like to make a Uni telemetry cable for Hobby Wing from a telemetry cable for Kontronik Cosmic, which I bought in your shop!
I only need the assignment of the colors on the board for both sides!
Greetings, Gernot
Greetings Gernot
Ah,
colors are matching for both sides so orange is connected with orange and brown with brown.
Red is disconnected from both sides.
gerry
So only brown and orange is needed?
Do I have to use the circuit board or can I solder the cables directly?
Greetings Gernot
Yes, you can solder them directly.
