Sensor divider and headspeed
showmeflyer
Just setup a Goblin 280 which has 24 pole motor with 1:1 gear ratio and head speed of 4200 plus. Can you increase the sensor divider to 12 instead of 8 and also increase the head speed to maybe 5000? I have a work around for the Hobbywing telemetry of setting the divider to 6 and gear ratio to 2 which I think gives the correct RPM reading but need more head speed to use the Spirit governor.
