Kosmik Telemetrie
gerry
Hello Tomas!
The telemetry with Cosmic and Jeti shows the correct values, but the mAh blink and set more often!
Where can the error be?
Greetings, Gernot
Greetings Gernot
this is OK, the only difference is that some telemetry values are updated more frequently and some less frequently.
For example Capacity and Temperature are updated less frequently, because there will be never fast change. This is because EX Bus line can be overloaded so in this way we can add also next things in the future.
gerry
You can change this? Especially with the mAh display it is very disturbing. At temperature or V or A it would not matter. If it with the capacity during an alarm is exposed then the alarm does not come.
Greetings Gernot
In the upcoming update it will be fixed. Thank you!
gerry
Hello Tomas.Wann comes the update, so the capacity indicator stops or flashes? I would now have to buy no J Log! Please ask for short info whether the problem is to be solved at short notice?
Greetings Gernot
Yes, it will be solved in the firmware that will be released in a few days.
gerry
Thank you
Greetings Gernot
