μSpirit on a Trex 150 - some observations and suggestions
Posted: Thu 10. Aug 2017 20:36:22
I have a μSpirit on my Trex 150 and am having some tuning problems. Basically there seems to be too much cyclic gain even on the lowest setting.
The problem manifests as a persistent nodding/vertical tail bounce that appears to originate from the head as opposed to the tail. I am using the standard mounting tape and have been through the setup process based on default Trex 150 settings. I have adjusted all cyclic parameters independently, including the 6 degree setting, to understand their effect on the flying characteristics of the Trex 150. I have tried a number of different balanced main blades and head speeds. All other hardware has been renewed twice with the exception of the motor, frame and servos. This should rule out bent shafts, bad bearings or worn dampeners.
Increasing the elevator filter to 2 from the default setting of 1 caused the heli to violently shake which resulted in a crash. After rebuilding the machine, I went the other way with the elevator filter and found that a setting of 0 made the heli flyable, but still with a slight cyclic wobble that appears to be on the elevator axis but may be on the aileron axis as well. Reducing the cyclic gain down to minimum setting of 20 further reduced the wobble but it is still there.
I should mention that I used to see the same rapid nodding when the gain was set too high on the original board. With the μSpirit, it seems that if an elevator filter setting of -1 or -2 was possible, the nodding would disappear and the cyclic performance would be perfect. Is extending the lower range of the elevator filter even possible? If the PID gains were adjustable, I would be inclined to leave the P as it is, but would reduce the 'I' value and maybe add some 'D' gain.
It took some time to get the tail dialled in. The gain range for the tail also seems to be on the high side for this little heli. I am using an XP7A Fast ESC flashed with Blheli on the tail. For those that are interested I have tested different bells (6 and 12 magnet) and different tail rotors (different shapes and sizes from 42mm to 65mm - all new and statically balanced). The optimum setup seems to be the original Trex 150 tail motor (now sold by Oversky) and Align's new '23' tail rotor. Tail gain is about 15. Any higher induces wag but the heli is still flyable up to a tail gain of around 65. The tail performance is acceptable. I haven't flown it hard yet but from gentle flying it looks like tail performance is about the same as it was with the original board. It is nowhere near as locked in as a well set up double brushless mcpX though.
I would like to know if it might be possible to improve the cyclic performance of the Trex 150. On the other hand the current firmware may have already been extensively tested on Trex 150 models and this problem may not have been seen before. If the former, I'd be happy to test a beta firmware if that would help. If it is likely that the nodding is caused by a problem with the model I will replace the remaining parts (servos, motor and frame).
As an aside, it would be good if throttle hold would shut off the tail motor after a few seconds.
All the best
Al
All the best
Al
