Diagnostic window not responding smoothly
jweber
I'm starting to setup a new Logo 550 and trying to calibrate my TX to the FBL. I'm in the diagnostic screen trying to set end points and it is behaving very oddly. It seems to only respond to aeleron input and everything changes when I move the stick. It also takes about a second or two to update it.
I copied my TX setup from another model I have running Spirit and have tried two different RX's.
I'm running Open-TX with an X4R-SB on SBus to the Spirit.
Are you talking about PC software or any other?
Diagnostic window is in the Spirit Settings, OpenTX integration, Android app, Wifi-Link and each is behaving little bit differently (as technically possible).
jweber
Sorry. The Windows application.
Ah, then it is possible that wiring is not OK.
I guess that you are using PWM connection.
Can you take a photo of the unit/receiver, please?
jweber
Just figured it out. Forgot to use the SBus inverter.
My mistake. Thank you for the help.
Ah, perfect.
Yes, smaller Spirit units require S-Bus Adapter for S-Bus.
Have a nice day!
