Set Level for Stabilization Mode
antperki@aol.com
Hi
I have the uspirit aero.
Is it possible to set level , for stabi, if you can't install the unit exactly in line with all 3 axes or you the aircraft to be slightly nose up in stabilisation mode?
Anthony
it is required to install unit perpendicular to all 3 axes of the model.
But regarding model construction (and possible nose up) it is not a problem.
The unit will level automatically.
