Rudder endpoints
lostmyheli
Tomas you stated in another topic
When you check the rudder end-points, you can see that the value are too high (you can see warning in the software about it).
This is caused by the servo arm being so short.
Please make it longer so the end-points are around 80 - 120 ideally.
Where is it documented that the end points should be between 80 and 120 ?
Where will you see these warnings ?
Also are these numbers the same for all models or are they size dependent ?
the end-point details are mentioned directly in the software - when you are configuring the sliders. As soon as the value is not good, it will warn you.
Non-optimal values are also highlighted (purple).
Optimal values are same for each model: 80 - 120 are ideal.
