Goblin Fireball
gerry
Hello Tomas!
Is it possible to extend the pole number up to 24 poles (12) (Goglin Fireball)? The motor is a 24 Pole: I now have 6 poles and 2.00 translation should actually be synonymous with the direct drive of the fire?
Greetings, Gernot
Greetings Gernot
Hello!
If gear ratio is 1.0, then your calculation is correct. Sensing divider at 6 and gear ratio at 2 will give you good result.
Update 2.5.0 will make it possible to set Sensing Divider at 12.
treys1
Thanks, I got the divider working correct now.
On the governor, the Max Head Speed is 4000 RPM but the Max on the Mini Comet is 5000 RPM. Will the governor be able to go up to 5000 RPM at some point?
Yes, in the next update.
treys1
Great!
Any idea on when that might be available?
gabs_mex
ZeXx86 wrote:Yes, in the next update.
Any Idea When will be available and also will the Fireball setup will it work for Mini Comet...
Maybe in one month, but not sooner.
Alternatively we can send you beta version, this can work immediately. But we can't guarantee operation.
Yes, you can use Fireball setup for Mini Comet.
