Different channel assignment Jeti EX-BUS?
stipsi
Have now my Spirit Aero 1.2.0 connected with Jeti EX-BUS. Why does the Rudder have a different channel assignment than in my remote control? In my DC-16 at servo output 4, in the Spirit menu channel 6? This should also be channel 4 or?
default channel assignement (in both unit and Jeti radio) should work out of the box.
Channel numbers may differ because you can assign to any channel any function in the radio.
Also it could differ, because each manufacturer have different layout. So numbers are not important at all. Important is mapped function.
You can verify corresponding functions in the Channels window or Diagnostic tab.
stipsi
Hello
Ok, thank you. I thought just because it matches my 2 Spirit Fbl.
Gesendet von meinem GT-I9195 mit Tapatalk
You can always reassign the channels in the same way as you have it in your other profiles.
Then it will be same. In Jeti you can assign any channel to any function. So this could be confusing.
