I'm looking forward to get my Henseleit TDF in a couple of weeks.
I'm wondering which setup I should use to start with, because there is no TDF default setup available in the wizard.
Do I need to change some specific values because of the linear servo drive?
Guido
Henseleit TDF setup to start with
you can use TDR profile or Default. Increase Pirouette Consistency to at least 170. Optimal will be probably 175 - 180.
for linear servos I just recommend to decrease Geometry 6° by approx. 25% since overall gain is too high. This mean that what you will find as a correct value should be then decreased (*0.75).
But all other parameters are similar to other models.
Hello!
How do I get the rear set nicely? I have already set the values very high. Can I still higher?
I'm not quite satisfied with the rear.
It turns a little to the right and at the same time downwards.
Although little, but it could be better!
My file I have attached!
Thank you!
Thank you!
- Attachments
- TDF Setup-Okt.4ds
- (255 Bytes) Downloaded 163 times
what is rear? Is it the rudder?
If yes, have you Gyro Gain configured to work in Head Lock mode?
This can be visible in the Diagnostic tab.
That is good, but it still does not mean that rudder will be in Head Lock mode.
For example if you have Futaba, then there could be NORM mode which will set it for Normal mode.
And you want Head Lock.
Please check Diagnostic tab as I have written earlier, only there you will see the mode that will be really used.
