[SOLVED] Jeti receiver - EX Bus Settings
Malc1
New build now finished and set up and just running through everything and noticed a few corrupted frame error messages and a low voltage error in the logs.
Are the correct recommended configuration settings to work with the Jeti EX Bus and Spirit available?
Just so I can be 100% sure that I have not missed anything early on.
If you will turn off the transmitter before power supply for the unit then it is registered as Low Voltage event + possible lost signal event.
In this case all is OK. But if it will be there even if transmitter is running it is not good.
Corrupted frames could happen from time to time, especially if you are changing the settings.
During flight there should be maximally 1-3 corrupted frames.
Malc1
Ok thanks I will test further later on without the unit connected to the software and check the logs.
Malc1
So If no log is available from the previously flight that is no errors at all during the powered up period?
Yes, if there is no critical error, then there will be no saved log.
