RPM displayed on Jeti DS16 - using Scorpion governor
Malc1
I am using the internal governor on a Scorpion Tribunus 200A esc and have RPM data being displayed on my Jeti TX.
Will this be the correct RPM being displayed?
I have noticed that in the Scorpion software when running the motor the RPM is much much higher and certainly can not be the RPM of the rotor head.
Or do I need to be using the Spirit governor for this work correctly, and be able to use it to set up the helicopter?
I have previously set up the correct main gear ratio in the Spirit software.
You have to set Sensing Divider and Gear Ratio. Then it should match the head speed. This can be done in the General - Governor/Throttle window (after enabling Governor temporarily).
Malc1
Great! Many thanks again.
