using spirit aero with 2 elevator servos and y lead.
Posted: Sat 23. Sep 2017 12:45:52
by Brendan
hi am trying to set up my katana plane with 2 elevators servos using y lead but both elevators are moving opposite directions also rudder travel is all when rudder stick is moved to left.
if any one could advise me how to correct all would be much appreciated.thanks .
Re: using spirit aero with 2 elevator servos and y lead.
Posted: Sat 23. Sep 2017 15:20:59
to reverse elevator servos you have to tick the CH2 servo reverse in the Servos tab.
To increase rudder travel you have to increase end points in the Limits tab (for both directions separately).
By moving the slider it will immediately show you where the limit will be.
Posted: Sat 23. Sep 2017 15:41:53
by Brendan
hi sorry i think you misunstood me 1 elevator servo is moving control down and other moving up thinking about it if i swap negative and positive wires on 1 servo should work
Posted: Sun 24. Sep 2017 10:05:42
Oh, this is problem.
Swapping two wires will not work, it will burn the servo.
It is needed to use some kind of servo signal inverter. or Spirit Pro unit which has two outputs for elevator servos.
Alternatively you will need to turn the servo around so it is in the same position as the first one.
