[SOLVED] Hobbywing 130 / Telemetrie Port with Fan...?
Franky13
Hello!
Can I actually connect the fan with the telemetry cable at the same time?
Yes. you can. For the telemetry only Signal wire is necessary.
Franky13
Uh, sorry!
I use the Telem UNI cable. Can I plug both cables, that fan and the Telem cable, into a port of the HW 130?
Yes, but you will need Y-cable or solder them together (or do a similar modification).
Franky13
Thanks Tomas :!:
