Oxy2, USpirit, Open TX...Bailout...
TSchwyn
Anyone have an Open TX file for the above combination? I have Tomas's file for the X7, but would like to go through the Actual Oxy2.
Thanks!!
Tom :D
TSchwyn
I've mostly figured out the Open TX programming for my Oxy2 from Tomas's file Spirit-FBL-x7 Open TX file.
Two questions? First regarding the OUTPUTS page in Open TX? Why are all the Min Max values set to -82.8 to 82.8, rather than -100 to 100? The gyro channel is an exception at -95.8 to 94.8. Is this just specific setup for the desired "feel" on the X7?
Second question: On the HELI SETUP page are the Long cyc, Lateral cyc, and Collective Weight set to Ime(rudder) for Cyclic ring, or another function?
I'm coming along learning Open TX programming, flew my Oxy2 with the QX7 transmitter yesterday!
I appreciate the assistance from everyone!!
Thanks Tom :mrgreen:
Hi, great!
There is nothing specific for Oxy 2 or uSpirit. Basically radio settings can be same for any helicopter and unit.
Regarding your first question - this is because OpenTX has different travel range from Futaba. To make it on par, it require little bit travel change.
So then in the software it will show +/- 100%.
For second question - if weights are set to 0 it should have no meaning. So if it is inactive, then all is good.
