Spirit on 700 heli
Ortie
I would like to fly the Spirit on SAB Black Thunder 700 Sport. Does it work?
Or would it better to go with the Spirit Pro?
curmudgeon
It is my understanding that the regular Spirit will work fine on any size heli including 700 and 800 size. However, since the regular Spirit has fewer pins than the Spirit Pro, you will need Y-connectors to connect a servo and 2S/BEC power to the same pin. Also, for Spektrum satellites users, the regular Spirit has only a single dedicated Spektrum port and requires a voltage lowering adapter for the 2nd Spektrum satellite.
