Stability causes backward drift
Posted: Mon 04. Dec 2017 1:21:17
I finally got my Spirit setup correctly to enable Stability mode. I tested both Normal and Acro today. I setup my TX to allow toggling Stability on/off.
I noticed a backward and slightly left drift when hovering tail in. With Stability off I could setup a nearly hands-free hover where no drifting was apparent. Toggle stability on and the heli immediately starts moving backwards and to the left. I double checked by CG and it was fine.
I performed this in both Normal and Acro stability modes. Directional control rates were in the 2-4 range during these tests.
Does this drifting show a swash level issue that somehow manifests itself only in Stab mode?
Any thoughts are welcome.
