[SOLVED] Rescue Collective Pitch
Genesis
Can someone explain the procedure for using this parameter as I am using stabilization in the following bank set up.
Bank 0 = Self Level w/ Rescue
Bank 1 = Normal w/ Rescue
Bank 2 = Acro Level w/ Rescue
When I tried to set my rarte to 50% in Bank 1 it seemed the rescue when activated would not set the pitch in the Bank 0 or Bank 2, and it did not seem to change pitch in the other two banks. I could not change the rate in the other two banks so I just set Bank 0 back to the original 60% rate and then all banks showed rescue working as it did before in all banks when bench testing.
Any help would be appreciated, thank you.
Kevin
I am not sure if I understand your configuration.
But whatever is configuration, it is not possible to set Rescue and Stabilisation for the same Bank.
So it is not possible to set:
and rest.
It can be Stabilisation OR Rescue for single Bank.
Rescue Collective Pitch can be configured for any Bank where you have Rescue. Then once activated it will set the Collective Pitch at 50% or any other configured value.
Genesis
Hello Tomas,
I apologize for the wrong bank switch information in my above post, it should of read:
Bank 0 = Self-Level / Stabilization
Bank 1 = Normal / Rescue
Bank 2 = Acro-Level / Stabilization
With help from a friend I was lead to the realization that the Rate (%) of Rescue Collective Pitch can only be set in Bank 1 in my set up as it works for the bank containing Rescue function and that you must set the Bank tab in the bottom RH corner of the software tab to the Bank 1 in my case to change the pitch % for bailout. This also changes the bailout rate or % of pitch in the other two banks as well when the rescue / bailout switch is activated which was proven with a bench test. Again sorry for the poor information presented in the initial posting of this thread.
Have a nice day & best regards,
Kevin
that is great!
No problem, I am glad that all is OK.
