uSpirit T-Rex 150 install tutorial?
Posted: Fri 08. Dec 2017 16:44:06
Hello Support
I am very interested in buying one of your uSpirit FBL units for my TRex 150 but as it very much looks like this is not going to be as straight forward an install as normal, I could really use a kind of a tutorial for the unique things pertaining to it.
Also if any others are reading this who have worked out any of these issues I would be happy to hear from you as well.
To let you know what I have been able to find...I have read a one thread here on one setup issue, and a few posts on thread on Helifreak for the announcement of the unit where some people asked some questions of its install to the 150, but while that gave me some info, some of that ended without fully explaining.
But from that thread it was interesting to read that you guys have tested one of these on the 150, and also from downloading the setup software that I can see there is a preset in it for the 150, so I am guessing you guys have done this and perhaps already worked out any of the things I am wondering about.
Currently for the info I have questions on right now are:
(1): Can this be used (and probably best used with) with the second version where the ESC, FBL unit and Receiver are all separate units?
IE, I am guessing I would still use the Align ESC PN: HEG15003?
But then with that if I understood the Helifreak thread correctly, it stated taking the two motors plugs (main rotor and tail rotor) and plugging them into the Aux and Ch4 plugs of the uSpirit unit?
If so and that is the case, then do I put the motor output lines of the Align ESC to some inputs of the uSpirit unit?
If not and this works another way, please let me know how this is done. With things also such as how do I get the BEC level power from the ESC to the FBL unit?
(2): If I am to remove and discard the Align FBL unit PN: HEG15002, from what I can see it looks like that part also contains the Rx Receiver, so how did you resolve that issue?
In looking it almost looks like it might be possible to separate the Futaba Rx part from the Align FBL unit, so is this how you did this?
If so could you please explain how this all was done to get both the power to the unit, and then the signal out of it?
From what I see, one side of this part has three pins going to/from it, and then the other side has the same, so are these the input and output for that?
All in all as I am using a Futaba Tx, I don't think I could find the room, or want to add the weight of any currently Futaba Rec and have that work out, so am hoping someone has a solution for this.
(3): From what I have read, the servo connections of the TRex unit are something called "Micro PicoBlade" and that the plugs on the uSpirit unit are JST-ZH, with both being a three wire for this.
So how did you guys resolve this, did you just redo the plugs on the Align servos or find or make up some adapters? If you found some, I would very grateful for a link to where I could buy them.
(4): I would very grateful for any pics you or anyone else could provide as to where and how the uSpirit unit was mounted, and also how the other parts either old or new were either connected and or mounted as well.
Am thinking maybe even a few pics could really help a lot with many of my above questions.
(5): Just to get this out of the way, I noticed in the units documentation it can be used with the BlueTooth connection plug, but it did not mention anything about a WiFi connection...so does this not work for any parts of a connection as well with your WiFi connector?
In a related question, I read in your instructions about connecting the unit to a PC for the setup, but I don't see an adapter for sale that goes from one of the plugs to a USB...so is this something I have to get or makeup myself?
If so could you give me the wiring parameters for doing that?
I guess for now that is all I have and am sorry to ask so many questions and I know you guys are probably very busy with many things, but as you can tell there are many things I haven't been able to find out by any other means, which if you guys have already done all this to one of these helo is also why I wondered if it might just even be easer to do a tutorial on the whole process of a install to one of these helos?
At any rate, I would be very grateful for any help anyone can provide.
Thank you
Thank you
