Hello Tomas, firstly thank you for providing a great FBL system and support.
I have a question regarding Castle Telemetry. Will the following connection still provide telemetry?
Castle Phoenix Edge > Telem CC cable > Jeti Rx > Spirit FBL
Or does Castle telemetry only work if connecting Telem CC Cable direct to Spirit FBL?
Thank you!
[SOLVED] Castle Telemetry through Jeti RX
thank you!
Connection must be so that Telem CC is in the unit, because data from the ESC are transmitted over the throttle wire. Jeti receiver can't process the signal, so it will not work in other way.
thank you!
