[SOLVED] Cyclic Sensor
gerry
Hello Tomas. Have today with my 700er the cyclic sensor set to 95 percent and he flies noticeably more accurate than before with 65 percent. I could detect any errors in flight. Did you ever that the value is so high? LG Gernot
Greetings Gernot
gerry
Greetings Gernot
with bigger helicopters it can work even with 100% gain in many cases.
But with very demanding maneuvers the servos can be loaded more. If you can't observe any bad behavior, then you can fly with this.
It has also impact on steering response.
Generally 60 - 65% is optimal.
