Throttle Endpoint Setting w/ Align RCE-BL50X ESC
Genesis
I am using the Spirit Pro with DSMX satellite and want to set the stock Align RCE-BL50X ESC that came with the model kit. I have used a Spirit BE and set endpoints on a CC Phoenix Edge Lite 50A and was wondering if the procedure is the same with the Align ESC when it comes to setting the throttle endpoints or how to proceed if different.
Regards,
Kevin
the procedure is little bit different for nearly all other ESCs than for CC.
If you have factory defaults in the unit then it should usually work out of the box all correctly.
If the ESC was used to and is already calibrated, then you have to recalibrate it again by powering up with full throttle (at 100% TC) and then lowering (to 0% TC). This procedure is described in the ESC manual.
Make sure that Governor in the unit is not enabled while doing this.
Genesis
Thank you Tomas, it was a breeze to setup and your advice was greatly appreciated.
Regards & Have a Nice Day,
Kevin
