[Solved] How to set RPM telemetry for a 24 pole motor?
Posted: Wed 24. Jan 2018 18:56:45
I installed a Spirit Pro on a SAB miniComet. I installed the HW 60A V4 ESC RPM wire to the Spirit PIT port. I am getting rpm telemetry in the Jeti radio, but the readings are incorrect since I do not have the correct "Sensing Divider" value in the Spirit. The motor is a direct drive, so I have the Spirit Gear Ratio set to "1".
The motor has 24 poles, so the Spirit Sensing Divider value should be "12". However, the Spirit software only goes to "8".
Considering that the Spirit software only goes to "8" but I need "12", is there a work around to this?
Thank you.
Thank you.
