Bluetooth module connection problem
Posted: Mon 05. Feb 2018 10:36:39
I have a problem connecting to the Spirit Pro using the bluetooth module, although it worked fine the first couple of times I used it.
Now, when I try to connect through the app, it connects to the module, but then it says that it couldn't find the spirit unit. The fbl connects fine through USB and I checked to make sure that telemetry is off.
The cables are connected properly and the module is blinking blue. When I try to connect, the blue led is solid for a short period and then starts blinking when I get the error of unit not found.
I also tried to delete the app and reinstall and also to delete cache and data. I have delete the bluetooth module and re-paired just to be sure, but the problem still persists.
Any advice?
Any advice?
