XSR with Spirit Pro
Posted: Thu 15. Feb 2018 21:06:01
by stipsi
Hello Thomas
Is it possible to do the Intigration-Cable like with Jeti with a 10kOhm resistor?
Can you do the Integration cable yourself?
Frsky XSR with Spirit Pro.
" For Experts: Alternatively you can modify your current Throttle cable by adding 10kOhm resistor between white (signal) and red (+) wires. In this case the Telemetry cable is not required.
Re: XSR with Spirit Pro
Posted: Thu 15. Feb 2018 21:17:41
unfortunately you can't make the cable yourself. There are few integrated circuits, but there is no resistor.
So without designed PCB and all the parts it is not possible even if you are experienced in electronics.
Posted: Thu 15. Feb 2018 21:34:25
by stipsi
Ok I understand. Then I need only the integration cable so that I can set telemetry of my CC ESC and Spirit Settings from the transmitter?
Posted: Thu 15. Feb 2018 21:37:10
For ESC telemetry with CC, you will need the Telem CC cable.
But to receive the data and allow integration with your radio, you need the FrSky integration cable.
Posted: Thu 15. Feb 2018 22:07:05
by stipsi
Ok, thanks Thomas!
Gesendet von meinem Lenovo A7600-F mit Tapatalk
