Which flybarless system to go with
You can post settings from the unit here.
Share and compare your configuration with other pilots!
the50machine
I am in the process of building a Align Trex 700. I have several of the Spirit FBL systems on several of my model 550 size helicopters or smaller. I am wondering if the standard Spririt FBL system will be large enough to handle a 700 class helicopter or if I would need to go to the pro version of the FBL system.
Ryan
smaller Spirit can work with 250 - 800 class helicopters with no problem. You might eventually need Y-cable (depending on wiring). So it can work at 700 as well.
Please note that you have posted the question in the AERO section, which is not related to helicopters but fixed-wing models.
But we will just move it to the correct section.
