Jeti Vario meter
demon450
I'm trying to setup a hard deck for rescue, so I need a vario meter.
Here is one from Jeti: http://shop.jetiusa.com/Jeti-Telemetry- ... titmv2.htm
It seems it has to be connected with either EXT1 or EXT2, in this case, I have to sacrifice either telemetry or Jeti integration.
I'm using Spirit pro, can I connect the Vario meter to the Spirit instead of receiver?
if you are using REX receiver, you can connect it all together.
EXT1 can be used for Spirit unit, EXT2 for the sensor.
demon450
ZeXx86 wrote:Hello,
Ok, I got it, going to buy a REX.
Thanks a lot! You are always so helpful.
