I was hoping to get a little help setting up telemetry on a Horus X10s with standard Fros. I am aware that I will not be able to get integration with out opentx which is fine but want to get the telemetry figured out.
I have a spirit pro, Hobby wing 160, currently a X4R but will be switching to an RX8R and Telem Uni cable.
I am making the switch from Spektrum and I was getting all the telemetry on the DX9 setup. Currently I have the pro connected to receiver thru Sbus, and the Telem UNI cable connected to main spektrum port on the pro and into the ESC. Is this correct or am I missing a cable?
Thanks,
Ben
Frsky Fros Telemetry
you will need the FrSky integration cable to make it work.
Basically everything is same as for the OpenTX, except you will not get the integration. But telemetry is using the same bus, so you will still need the integration cable.
You can proceed according this guide regarding Wiring:
Yes, you are right.
