Horus X10S rb1volt value way high.
Posted: Tue 27. Feb 2018 17:22:30
by TSchwyn
I'm setting up a new Horus X10S transmitter with my Spirit Pro in TRex 700. Have the correct Spirit cables installed between the Fr Sky receiver and the Spirit Pro. I'm getting the correct voltage value on the Horus monitor. (12s pack at approximately 45.1 volts storage ) However when setting up switch to get audio "Play Value" on Horus its reading back about 900 volts. Any suggestions on why I'm getting the extreme multiplier?
Thanks for the help!!
Tom
Re: Horus X10S rb1volt value way high.
Posted: Tue 27. Feb 2018 21:31:16
isn't your radio just too close to the receiver?
Are there other values that are behaving in this way?
Posted: Wed 28. Feb 2018 1:48:53
by TSchwyn
Tomas,
Thanks for the response! It doesn't make any difference when I increase the distance between the transmitter and the heli. I also checked RB1_Amps, and RB1_Consumed(MAH) they are giving the correct value,not a drastic overstated value. Any other suggestions?
Thank you!!
Tom
Posted: Wed 14. Mar 2018 10:32:29
we will contact FrSky to check what could cause this.
Could you please tell me, what OpenTX/FrOS you are using?
Posted: Fri 16. Mar 2018 11:01:38
by TSchwyn
Tomas,
The transmitter is an X-10S Horus its firmware is the latest version 1.2.03. The master receiver is an RX8R its firmware is the latest version 170208. The slave receiver is an R-XSR its firmware version is 171009. The slave receiver must have telemetry turned off. Only the master receiver has telemetry turned on.
Thank you very much for the help!!
Tom
Posted: Fri 16. Mar 2018 11:04:19
Thanks a lot!
Did you checked if there is any difference if you will disconnect slave receiver?
Posted: Fri 16. Mar 2018 12:43:51
FrSky is asking, if you can record a video of the problem - at least short so they can see what is happening. For sure it is not normal.
Posted: Sat 17. Mar 2018 17:10:08
by TSchwyn
Tomas
Here is a video of my x-10s showing issue.
Thanks Tom
Posted: Sat 17. Mar 2018 18:30:54
Thank you for the video.
Now I understand the problem. Unfortunately it look like bug in the FrOS.
Now they have video so I believe they can fix it.
Posted: Sat 17. Mar 2018 20:19:59
I have received message that the problem could be caused just by outdated or wrong sounds at the SD Card.
Can you make sure that they are stock and the latest version?
