[SOLVED] Lower governors rpm
you can set it without any problem.
The minimum is approximately 750 RPM
I think you are seeing 1500 as Max head speed. But it does not mean you can't set lower. Just set TC to 80% to achieve 1200 RPM. 100% will result in 1500 RPM.
You are welcome!
