Fixed Angle
threeDfreak
hello,
i have another idea for the Spirit Aero.
A "fly by wire" control, in which it interprets the control stick deflections as command angles for Pitch and Roll. For example,
pushing and holding your control stick maybe 50% to the left will cause your model to enter a level altitude banked left turn in maybe 20° angle. The Spirit control thr angle. The RC Plane goes not more and not less angle.
thank you for the suggestion.
I am not sure if I understand perfectly, but I think that this function is already in the Aero.
You can set maximum angle for Stabilisation (Normal) mode by changing Direction Control Rate value.
threeDfreak
ok, i have tested it.
That was it what i meaned "Direction Control Rate"
Thank you :P
