µ Spirit and Blade 250 CFX
rolandk
I want to use a µSpirit on a Blade 250CFX.
Can anybody help me, how to make the setup of the tail rotor
(Rudder endpoint values, how can I prevent tailrotor from turning, when in subtrim mode, is throttle range the same as Blade 230S????).
Thanks in advance for every answer.
With best regards
Roland
Hello Roland,
yes, first you can start the Setup wizard as usually, then during the process you will see option for Rudder control type where you will have to set the Motor.
When configuring Rudder end-points you will simply define travel range for the Rudder ESC with these two values.
One value will be for complete stop and other for full throttle.
Once configured it will work just fine.
The upcoming version will be much clearer in that aspect and there are also other improvements for getting also better performance.
If you wish, we can share such version right now.
rolandk
Hello Tomas,
thank You very much for your help.
The ordered µSpirit is announced for tomorrow, so I can use your tips at once.
How can I share the new Version you mentioned?
With best regards
Roland
Hello Roland,
I will contact you in a private message.
