Hott Telemetry - Interpretation of Vibration Values????
rolandk
Hello Tomas,
how I told in a former post, I´m using now after the last software revision for Align ESC the hobbywing telemetry and it works very well.
One question I have nevertheless to the Vibration level.
In the manual is written, vibration level is shown in FUEL and ALT (GAM Sensor).
I get the values, but I don´t know how to interpret them. I don´t know, which values a normal and which values are standing for example very high vibrations.
May be a stupid question, but I would be very grateful if I get some help.
With best regards
Roland
the value is showing all vibrations that can't be filtered. So anything above 0% is potentionally bad. But in general it is not possible to achieve this condition, especially in 3D flights.
If you can see vibrations under 10% during hovering, then all is great. If there is 30 - 50% it is very high.
rolandk
Hello Tomas,
thanks a lot for Your quick reply.
Please let me ask two more questions to this Topic.
When I depict my values in a graphical presentation with the Data Explorer from Graupner, I get the percent values only in the ALT Category.
The FUEL Category is represented only with a straight horizontal line.
In what Proportion have I to see These two graphics?
If the vibrations shown in my telemetry would be between 30% and 50%, then the vibrations are very high, like You said. Would such values been shown in an after flight log as warning "Vibration Level is very High"?
Thanks in advance and with best regards
Roland
rolandk
Hello Tomas,
just one inaccuracy in my last post.
The values for vibration in the ALT category are of courde not in percent, but in meters.
My average value in hovering mode is here 3,76 meters.
with best regards
Roland
I am sorry, but I am not familiar with Graupner log viewer.
It is also dependent on used sensor - vibration level is just in one variable, but the variable name is changing.
So maybe you are trying to find something that is not there.
If you can see just stright line it mean there are no data.
Yes, if vibration level is too high the log will contain such message. It is using same data as you can see in the telemetry.
