Hoobywing RPM Signal with Spektrum 4649T
Amdxp
Hall I have the Spektrum 4649T receiver connected to the Spirit Pro according to the information on the homepage now my question is where the cables of the Hobbywing 130 controller come in so Bec is clear on Aux 1 and Bec slave on Aux 2 but where is the RPM signal since the Hobbywing has a separate RPM signal
Greeting
if you are not using Governor from the unit you do not have to connect the cable.
If you want, then connect it at the PIT pin. You will need to modify the connector and move the wire in the middle. Then all will work.
