Micro spirit and bluetooth
Pking
Can i connect and use the Bluetooth module with the micro spirit ?
yes, you can use any peripheral that is compatible with Spirit units.
You might need just adapters (up to 2x JST-Servo). If you have receiver with a free servo port, you can use this port for powering. And communication cable will be connected by the JST-Servo provided for the USB interface.
Pking
Thanks you are very fast to answer.
I am setting up for a 230S, I read on a post about confit for a tail motor but can’t find the parameters and what I have to do in this situation.
In the software they’re is the 230S preset but not sure what has to change.
you should configure everything that is in the Setup wizard to make it work correctly.
