[SOLVED] Diabolo 700 Preset Advice
CFerry
I see there is a Triabolo present in the wizard. Would this work well for a Diabolo 700? Or would I be better to go with a different present (2-blade heli).
I'm running the dampened head on my Diabolo.
Thanks!
It is possible to use Triabolo preset, there are minor differences - only in Cyclic Feed Forward and Cyclic Gain.
CFerry
Great. I'll start with Triabolo then :) .
Thank you so much Tomas.
Chris
CFerry
I did maiden flight using Triabolo preset (my heli is Diabolo 2 blade; 695 Cyclones). The only problem was a constant elevator oscillation during hover. I reduced cyclic feed forward as you suggested (down from 5 to 3) and it is flying very well now!
Thank you ZeXx86!
Chris
