Servo List
LogoX2
After speaking with Align USA they informed me that the DS820 freq setting is 200hz. The BeastX servo list also says 200hz for cyclic. The Spirit Servo List says 333hz for the Align DS820 when used as a cyclic servo. Is this the correct setting for this servo if used with Spirit ?
according our tests it can work well at 333Hz. But if Align is saying it can't work at higher frequencies, then I recommend to set lower.
Are they counting with option that the FBL unit can set 333Hz? Since not many units can allow this. I mean that they maybe not tested it. But they should know what is good for their products.
