[SOLVED] Spirit Pro Problem with the tail
TomF
banko.4ds
(255 Bytes) Downloaded 83 times
the tail doesn't lock properly.
Tail rotation stops only in one direction.
It's a Goblin 550 with 550 Rapids and 2000 RPM.
kind regards
please decrease Pirouette Consistency to 175 first.
Then tick the Servos/Subtrim (tuning) and check if rudder servo arm is exactly at the center.
At the same time your tail slider should be approximately at the center, but closer to the tail boom - there should be a slight angle between tail blades (3-4°).
Lastly please make sure that the Rudder End-points are configured so that the rudder servo can use full range, especially closer to the boom - this is important in order to be able to hold well.
Once all is done, you should be able to increase Gyro Gain. Usually the gain value is around 50%.
TomF
Thanks,
I had some mistakes in my setup.
Maybe it works now.
Check it in the evening ;)
Tom
TomF
The tail is working !!!
Very well, thank you for the message!
